I have an Industrial Connection Thing in ThingWorx, which has some Channels and Tags with data. I can get the names of all Channels and Tags through a service, but is there also a way to get the values of the tags programmatically? I didn't find a service which outputs the values.
Thank you
Hi @VG_10732813 look at the below community post, looks like the same use case you are looking for.
