Get Values of Tags from Kepware programmatically
VG_10732813
6-Contributor
I have an Industrial Connection Thing in ThingWorx, which has some Channels and Tags with data. I can get the names of all Channels and Tags through a service, but is there also a way to get the values of the tags programmatically? I didn't find a service which outputs the values.
Thank you
Hi @VG_10732813  look at the below community post, looks like the same use case you are looking for.
https://community.ptc.com/t5/ThingWorx-Developers/Display-Kepware-tag-tree-in-mashup/m-p/880470#M62720
