Get list of all properties implemented in a ThingShape
amittal-3
Is there a way to get all the properties implemented in a ThingShape? For a Thing if I use the method "GetPropertyDefinitions()" it works fine
var params = {
			category: undefined /* STRING */,
			type: undefined /* BASETYPENAME */,
			dataShape: undefined /* DATASHAPENAME */
        result = Things["MyThing"].GetPropertyDefinitions(params);
//This Works fine, I get the infotable with the list of all the properties
; but when I use it with ThingShape, it returns me a blank infotable.
var params = {
        result = ThingShapes["MY_THINGSHAPE"].GetPropertyDefinitions(params);
//This returns a blank infotable
Any help would be appreciated.
Thanks in advance
- Aditya Mittal
1 ACCEPTED SOLUTION
You can try this one:
 var params = { type: undefined /* STRING */ };
// result: INFOTABLE dataShape: PropertyDefinition
var result = ThingShapes["TS1"].GetInstancePropertyDefinitions(params);
Best,
Adam
3 REPLIES 3
Best,
Adam
Is there a way to pull Thing shapes that are in a implemented Thing?
amittal-3
(To:kthamma)
I think you can try to use the service 'GetImplementedShapes'. Its a generic service. It will return you the list (infotable) of all the implemented thingshapes for a particular thing.
I hope it helps!!
Aditya
