The download for simulated data appears to be a html file rather than an xml file with valid data. When trying to import
When trying to import the file it returns Import failed with the following application log error
"Invalid request: org.xml.sax.SAXParseException; lineNumber: 2; columnNumber: 10; DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true."
Hello @SF_9687766,
Have you tried using the left click to download the Things_House_data_simulator.xml or Save Link as to get the xml file.
Thank you for the link to download the simulation code. That is working fine now.
