is there a way to get the latest timestamp entry from an InfoTable which has around 20 timestamps rows?
hi @Velkumar ,
Thanks for it; I am not sure how I missed it.
let sort = {
ascending: false
result.Sort(sort);
Hello @pshashipreetham,
Here is some code that should do what you want:
// if your dates are strings
let objects = [
{ date: "2023-04-19" },
{ date: "2023-04-20" },
{ date: "2023-04-21" },
let newestDate = new Date(
Math.max.apply(
null,
objects.map(function (obj) {
return Date.parse(obj.date);
result = newestDate.toDateString(); // Output: Fri Apr 21 2023
// if your dates are dates
let objects = [
{ date: new Date("2023-04-19T12:00:00Z") },
{ date: new Date("2023-04-20T12:00:00Z") },
{ date: new Date("2023-04-21T12:00:00Z") },
let newestDate = new Date(Math.max.apply(null, objects.map(function(obj) {
return obj.date.getTime();
Hope this helps.
Jens
hi @Velkumar ,
let sort = {
ascending: false
result.Sort(sort);
