Get the latest Timestamp from Infotable
pshashipreetham
 is there a way to get the latest timestamp entry from an InfoTable which has around 20 timestamps rows?
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
hi @Velkumar ,
Thanks for it; I am not sure how I missed it.
let sort = {
    ascending: false
result.Sort(sort);
Shashi Preetham,
3 REPLIES 3
Hello @pshashipreetham,
Here is some code that should do what you want:
// if your dates are strings
let objects = [
  { date: "2023-04-19" },
  { date: "2023-04-20" },
  { date: "2023-04-21" },
let newestDate = new Date(
  Math.max.apply(
    null,
    objects.map(function (obj) {
      return Date.parse(obj.date);
result = newestDate.toDateString(); // Output: Fri Apr 21 2023
// if your dates are dates
let objects = [
  { date: new Date("2023-04-19T12:00:00Z") },
  { date: new Date("2023-04-20T12:00:00Z") },
  { date: new Date("2023-04-21T12:00:00Z") },
let newestDate = new Date(Math.max.apply(null, objects.map(function(obj) {
  return obj.date.getTime();
Hope this helps.
Jens
Hi @pshashipreetham
You can use the 'Sort' snippet to sort rows in InfoTable
/VR
hi @Velkumar ,
let sort = {
    ascending: false
result.Sort(sort);
Shashi Preetham,
