When expanding the search result (tree view) the method GetPartStructureWrapped returns HTTP Error 500
Error in invoking service Things_ptc-windchill-demo-thing, GetPartStructureWrapped, Things, ptc-windchill-demo-thing, Services, GetPartStructureWrapped. Error from the server: "Wrapped com.ptc.connected.plm.thingworx.JSONServerException: JSON Server error HTTP 500
full error from Application log attached
ptc-thingview-extension 1.1.82
ptc-windchill-connection-extension 1.8.0
Reinstall of all extensions helped
See http://support.ptc.com/WCMS/files/164699/en/WCTWXExtension.pdf page 18 - 24
Hi.
When you say 'Reinstall of all extensions helped' did that ultimately solve the issue?
If so, please go ahead and mark the issue as solved.
Thanks!
-- Craig A.
Hi.
Thanks!
-- Craig A.
