I have used GetProperties() service in my mashup. I checked the Automatically update values when able property of the service. On serviceinvokecompleted event of the service, I am calling different service. Everything is working fine in local but When I hosted in server it's not working.
Raju
Hi raju k,
would be helpful in this case.
Please make sure all the properties which are changing are bound to some widget otherwise GetProperties() will not be invoked.
I would also check the log and check to see if it is actually able to establish a WS connection to your Client.
