Getting default Name with Marker in Google Map?
mpatel-21
Hello Exper,
I have two marker with Location with Name like Name1 , Name2 FYI I already binding this with Map and shows me as well and in tooltip also visible it's name.
But I wanted to Marker default display with it's name. Not require any hover for tooltip. Please help me to solve this issue. FYI I put one output image with this question.
In Below image Marker with it's name display I want exactly like this , I was try many things but not working for me.
2 REPLIES 2
Aanjan
(To:mpatel-21)
Mayank, that is not an out of the box functionality. The closest you can get that, as you mentioned is using Tooltips. You would need to make a custom Map widget for this.
mpatel-21
(To:Aanjan)
Hello Ravi,
Have you idea about how to develop custom Map widget ? I am not creating any custom widget before.
Mayank
