Getting default Name with Marker in Google Map?
mpatel-21
2-Guest
Hello Exper,
I have two marker with Location with Name like Name1 , Name2 FYI I already binding this with Map and shows me as well and in tooltip also visible it's name.
But I wanted to Marker default display with it's name. Not require any hover for tooltip. Please help me to solve this issue. FYI I put one output image with this question.
In Below image Marker with it's name display I want exactly like this , I was try many things but not working for me.
Mayank, that is not an out of the box functionality. The closest you can get that, as you mentioned is using Tooltips. You would need to make a custom Map widget for this.
Hello Ravi,
Have you idea about how to develop custom Map widget ? I am not creating any custom widget before.
Mayank
