i have created Organization and login page and give the permissions to all entities so that after login all entities should be visible but after login i didn't see menu and in logs it's showing an error like "Invalid Request Exception: File Repository [SystemRepository] does not exist" please share some solution on this.
Read this article - "Encountering error "InvalidRequestException: Not authorized for Create" when Configuring the connection between ThingWorx Analytics server and ThingWorx Analytics Builder": https://www.ptc.com/en/support/article/CS261073
Hi @ru.
Try testing it with the Administrator login. If you're no longer seeing the error, you likely have a permissions issue. If you still see the error, it's most likely a typo or misconfiguration.
Regards.
--Sharon
