Google Map Marker Label
flucciarini
Hi guys,
Is possible to view near marker in google map widget a label binding a properties of things like the image below.
1 REPLY 1
ankigupta
(To:flucciarini)
Hi Fabrizio Lucciarini​,
We have the option to add Tooltip for the markers so that if anyone hover on that Marker a Tooltip with the details would show.
I am not sure if the exact feature is currently available in the Core Google map widget but we have the option to create your own widget with the custom features. You can also use the current Google Map widget as the base.
I hope it helps.
