Google Maps API error: MissingKeyMapError
Re: Google Maps API error: MissingKeyMapError
I had the same problem. I ended up hand modifying index.html from his location: Tomcat 8.0\webapps\Thingworx\Runtime
I don't think the extension import is working. My guess is that the metadata.xml file is supposed impact the "managed" area of this file. It's not doing it on my system so I changed it myself.
    <!-- *** MANAGED SECTION DO NOT EDIT *** -->
    <!-- BEGIN_EXTENSION_SCRIPTS -->
  <script type="text/javascript"  charset="UTF-8" src="https://maps.google.com/maps/api/js?key=YOUR_KEY"></script>
  <script type="text/javascript"  charset="UTF-8" src="/Thingworx/Common/jquery/jquery.jsPlumb.min.js"></script>
    <!-- END_EXTENSION_SCRIPTS -->
I left off the "sensor" argument based upon google's direction.
Intente todas las opciones pero solo me funciono lo siguiente:
url="https://maps.google.com/maps/api/js?key=MY API KEY" description="" isDevelopment="false" isRuntime="true" />
eliminando el parámetro sensor ya que no es obligatorio.
Lo edite en el archivo metadata.xml de la extensión de google maps.
