I am trying to develop the custom widget. I already installed Eclipse eclipse-jee-2019-06-R-win32-x86_64.
In my Eclipse project, I don't have this option "Run as -> Gradle (STS) Build". For that, I am trying to install below Gradle plugin from Eclipse Market place.
I am getting error while installing the Gradle . Please refer the attachment.Could you tell me how to solve this issue?
Thank You in Advance
Latha
I apologize, I misread your question. Since the problem is with the Eclipse marketplace - you may need to reach out to their support/forums as it's not a PTC product.
Try updating the build.gradle in the Eclipse extension project as follow :
dependencies {
compile fileTree(dir:'twx-lib', include:'*.jar')
compile fileTree(dir:'lib', include:'*.jar')
compile group: 'org.json', name: 'json', version: '20090211' // add this line
// add this block
repositories {
jcenter()
Thank you for information.
May I know which file I have to update ?
Latha
Thank you for reply.
I will post into Eclispe.
