Added a advanced grid in a Responsive Container, but the Advance Grid doesn't show vertical bar's.
Shashi.
Hi @slangley ,
This is Fixed, this is due to the Grow Ratio in the responsive mashup, Increased Grow Ratio and Enabled the Scroll bar in the layout Tab.
Thingworx Version: 9.2.2
Hi @Shashi_Preetham.
What version of ThingWorx are you running? Do you see the same behavior with different browsers?
Regards.
--Sharon
Hi @slangley ,
