i am working on a requirement where i need create, delete and edit a row in a grid widget.
Creating/adding a new row is working fine but i am having problem in restricting edit option.
I have 4 columns in my grid col_a, col_b,col_c and col_d. Out of these 4 columns, col_a and col_b are keys for my data shape so should be not be allowed for editing. And only col_c and col_d should provide edit option.
currently if i modify column properties and make keep col_c and col_d as editable then i am not getting col_a and col_b when i try to add a row. If i keep all 4 columns as editable then i cannot restrict user to edit col_a and col_b which are key fields.
Hi @Vimal_Rawat
Give these steps a try:
By following these steps, you should be able to successfully restrict editing for col_a and col_b while allowing edits for col_c and col_d. For more detailed guidance, refer to Editing Data within the Grid Widget in the ThingWorx Help Center.
Please let us know if you have further questions.
Regards.
--Sharon
I have this grid with 4 columns that are visible. i have added the option '+Add' to add a new row.
Currently i have made only column 'FriendlyProgramName' and 'CycleTime' as 'editable'. so i get option to edit only these two columns when i hover over it.
But when i try to click on '+Add' i see only columns 'FriendlyProgramName' and 'CycleTime', whereas i need all the four columns when creating new row.
What i want to achieve is:
1) while creating a new row i want to provide details for all the column.
2) while editing only 'FriendlyProgramName' and 'CycleTime' should be available for edit.
Hi @Vimal_Rawat
Can you send some screenshots and recreation steps. It would also be helpful for you to provide the mashup and supporting entities so we can test it here.
If you'd rather not share artifacts here, I'm happy to open a case on your behalf.
Regards.
--Sharon
