Grid widget in Popup window is gone
Yoshihiko.N
Dear Developers,
I put a grid widget in a mashup and try to show it up as "popup".
however, we cannot see the gridwidget eventhough I dont set any "visible" status and the size of the  popup window is also enough big.
I change the configuration of navigation function from "popup" to "new", then the grid is appeared.
could anyone tell me why this happens and how to show the grid up with popup ?
my thingworx version is ThingWorx 9.3.6-b1323
sc of mashup design.
sc of when we navigate the window as "popup".
sc of when we navigate the window as "new".
Velkumar
(To:Yoshihiko.N)
Hi @Yoshihiko.N
Not able to reproduce this issue in Thingworx 9.3.6-b1323
I have attached my entities for your reference.
Check whether any other imported extension causing this issue. Also if possible please share your entities so I can test them in my env
/VR
Velkumar
(To:Yoshihiko.N)
Hi @Yoshihiko.N
/VR
Yoshihiko.N
(To:Velkumar)
Hi @Velkumar ,
Thank you for your prompt reply.
let me compare to your entity.
Yoshihiko.N
(To:Velkumar)
Hi @Velkumar ,
Thanks to you, I can fix the issue.
the route cause was the configuration of tabset.
I configured the size of tabset(and mashup as well) is static since I assued this mashup is used as popup.
the only difference between yours and mine was this size configuration, then the issue was fixed after I changed it to "responsive".
