Dears,
Anyone have practice can share regarding the HA architecture regarding Windchill Navigate?
Does Thingworx connection server a required componet in this kind of configuration?
From the "ThingWorx 8 High Availability Administrator’s Guide":
ThingWorx HA requires the following:
ThingWorx 8.0 or higher
Two or more servers to operate ThingWorx in a HA environment
Apache ZooKeeper 3.4.5 or higher
Three servers to operate ZooKeeper in a HA environment
From the ThingWorx Connection Server Installation and Operations Guide:
The Connection Server handles all message routing to and from devices [by Thingworx.]
Navigate only makes requests to Windchill or other PLM applications, and so should have no need for the ThingWorx Connection Server.
If this reply provided the information you needed, can you please mark it as the solution?
Thanks.
