HTTPS with ThingWorx mashups
SOLVED
Is there will be any impact of using HTTPS with ThingWorx mashups/pages?
Tags (1)
Re: HTTPS with ThingWorx mashups
Bavithraa Marimuthu​: It is always good to use a secured protocol i.e. HTTPS for the security perspective. However, there will be some overhead and handshake during communication requests but should not be impacting the performance negatively.
You can refer blog for more details on improving performance  How to improve mashup loading performance
-Durgesh
-Durgesh
When I imported a SSL certificate (not a self-signed certificate) to generate a .keystore for tomcat (8.0.33), my remote device didn't recognize it and coudn't connect to the server (TWX 7.1.2, Ubuntu). The error is:
TW_VALIDATE_CERT: Certificate rejected.  Code: 20, Reason = unable to get local issuer certificate
twTlsClient_Connect: Error intializing TLS connection.  Invalid certificate
Is it an entrust ceritficate? Configuring Entrust certificates in WSEMS for SSL pinning.
(Please ensure you are using the right pem file)
It's not an Entrust certificate. For testing purpose, I use a Let's Encrypt certificate. And I don't use EMS but the C SDK. Can you tell me what I can do to configure the connection, something related to:
"certificates":    {
                  "validate":          true, //Not validated model is not recommended
                      "allow_self_signed":  false, //Self signed model is not recommended, yet theoretically better than non-validated
                      "cert_chain":      " " }
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
