Why the header's height is shrinking and expanding automatically? Does the contained mashup height is affecting header's height? How to fix header's height constant??
Could you please elaborate on your use case? Does it change when you resize the window?
No, I figured out that responsive mashup header's height is more than advanced responsive mashup's height. I want Both's header should looks similar as we having n number of mashups in project. I didnt find height property for header to fix it. Can you help me in this? any css code available for this?
