Help for Azure IoT Hub Connector Demo Issue
SOLVED
Re: Help for Azure IoT Hub Connector Demo Issue
Please make sure that you follow the azure IoT connector guide strictly first, then if you happen to see:
Exception in thread "main" groovy.lang.MissingMethodException: No signature of m
ethod: java.lang.Long.call() is applicable for argument types: (java.lang.Long)
values: [2]
in the client console, then use the zip file I posted, unzip it and copy the azure-iot-edge-demo-2.0.0.141.jar file  to replace the original one (remember to backup first), then restart the client, it should be OK. Otherwise please provide the log file for further debug.
@ShengLiangQiu,
Could you explain more for your building tools?
Are you also using the Groovy JsonBuilder with a different version?
This will help us understand more for the issue and note it down in our knowledge base.
Br,
Anna
@ShengLiangQiu wrote:
Seems a bug of the Groovy JsonBuilder of Azure IoT Connector 2.0, I have recompiled the code and please unzip attachment and copy the jar file to replace the same one under demo\edge-device-demo\lib, everything is OK.
@ShengLiangQiu,
Br,
Anna
Tags (1)
Anna, the building tool is eclipse, groovy-all-2.4.5.jar to build the new version.
