You need Administrator rights in order to use the import/export feature in Thingworx.
Best regards,
Adrian
thanks !
Adrian, can i ask you one more question? my VM simulator can work but now they it shows cant connect to my to my end point, what is the problems?
Can you post the entire log? Also, what are your current configurations set in in the TrainingConfig file?
Hi, here's the pictures
thanks
Can you try using localhost or your actual IP instead of 127.0.0.1 in the TrainingConfig.json? Also, just to make sure, the Platform is available at port 80, correct?
I tried to use my own IP and its connected but then the handshake part keep timeout. As for the port 80 its available and i am using it,
here the picture of the simulator
