History
slua
History
Just wanna ask why is the history stops at Sep 30 only even though I am still running it.
10 REPLIES 10
Aanjan
(To:slua)
Can you try changing the values manually and see if they get logged?
slua
(To:Aanjan)
Yea when I change the values manually it get logged, but when it auto change values  the history does not logged
Aanjan
(To:slua)
Is this specific to the VM-TR Things or does this happen for all Remote Things? Can you try using the sample/ example.lua files in the EMS (along with the LuaScriptResource) to connect to a new RemoteThing, bind the properties and then logging them to a Value Stream?
slua
(To:Aanjan)
its only apply to the VM-TR Things. And i don't know why i can't seems to get values from the MQTT broker using this MQTT support in ThingWorx to guide me. I cant get values at the broker but then not in the ThingWorx
Aanjan
(To:slua)
Would it be possible for you to delete and recreate VM-TR1?
slua
(To:Aanjan)
Still the same, I need to manually change the values then it will record down.
Aanjan
(To:slua)
What version of ThingWorx are you running? Any chance you can export the entities you are using and also possibly attach your EMS too?
slua
(To:Aanjan)
I'm using ThingWorx composer 5. What do u mean by export the entities and attach ems?
qn
(To:slua)
Regarding the entities, I think he means the function "Export" from the menu "Import/Export" --> Export --> To File.
slua
(To:Aanjan)
Do you mean this?
