Just wanna ask why is the history stops at Sep 30 only even though I am still running it.
Can you try changing the values manually and see if they get logged?
Yea when I change the values manually it get logged, but when it auto change values the history does not logged
Is this specific to the VM-TR Things or does this happen for all Remote Things? Can you try using the sample/ example.lua files in the EMS (along with the LuaScriptResource) to connect to a new RemoteThing, bind the properties and then logging them to a Value Stream?
its only apply to the VM-TR Things. And i don't know why i can't seems to get values from the MQTT broker using this MQTT support in ThingWorx to guide me. I cant get values at the broker but then not in the ThingWorx
Would it be possible for you to delete and recreate VM-TR1?
Still the same, I need to manually change the values then it will record down.
What version of ThingWorx are you running? Any chance you can export the entities you are using and also possibly attach your EMS too?
I'm using ThingWorx composer 5. What do u mean by export the entities and attach ems?
Regarding the entities, I think he means the function "Export" from the menu "Import/Export" --> Export --> To File.
Do you mean this?
