For some reason, the horizontal bars of the label chart widget does not line up with the y-axis values. I have a value of 1 but the bar height looks below 1. This occurs with other values as well. Please see the image below.
Hi @Willie.
According to the internal ticket, it was addressed in 9.0 per jira TW-70626. The following widgets were added in 9.0, so specifics about each one were not explicitly called out in the release notes.
Bar Chart Widget
Line Chart Widget
Scheduler Chart Widget
--Sharon
I am on ThingWorx 8.5.3-b123
I did not see it in the release notes for 9.0.1, 9.0.2, 9.0.3. Was it fixed in a later version?
Hi @Willie.
Bar Chart Widget
Line Chart Widget
--Sharon
