can I change the tab orientation from horizontal to vertical? If yes, how? and if no, what can I use as an alternative for it?
You can't change Tab orientation, but you may use Menu Widget which allows to be set vertically and you can do almost the same as you do with Tabs, actually we use both depending on the situation.
Best Regards,
