How can I in a thing service script get the name of the object that fired of the service event ?
If you mean the outer service that fired a service you are out of luck, event you can't ask current executing service.
I have question on GetImplementThingsWithData Service. Actually I would like to know how to fetch all data from GetImplementThingsWithData into my own service and apply filters on those date so that I can create a infotable of filtered data. Please give me solution for the same
Not sure I fully understand the question. You want to use getImplementedThingsWithData in your own service, then modify/filter the result of it, and output an infotable? To do it through a service, you may use the GetImplementedThingsWithData service which results into an infotable:
You may further add the filters needed with the snippets or your own code to produce a new/filtered infotable.
You may also use a mashup, bind all data from the GetImplementedThingsWithData service to a, say, Grid, and then bind it to a data filter widget.
Events readily expose that in the Inputs/Outputs table
If it is import for you to know Outer invoking services, then pass that in as Service Input Parameters
