I have an advanced grid that display all the information i retrieve from DB using SQL query and i would like to add a button that triggers a service to edit the register in m
y DB that corresponds to that row(see screenshot)
You can't do that directly perhaps in the adv grid, you could have a button aside the grid and have that use the selected row in the grid.
Hi @YD_9850038.
If you feel the previous response answered your question, please mark it as the Accepted Solution for the benefit of others in the community.
Regards.
--Sharon
