Hi Everyone,
I am having following scenario :-
One master page and one Mashup both I embedded into one (mashup having master page), where master having there own customized Theme & mashup having there own separate Theme, when I am executing mashup (Runtime) then master theme influence mashup page UI (mashup page label, button , text box etc getting display as per master theme instead of mashup theme).
I know there is one property inside mashup named as "UseMasterTheme" which is Boolean one, I also Untick that property but still facing same issue.
Using Thingworx version 8.5.9
How I can resolve this problem & is there alternative ways to do this (having master & mashup different Theme & its work as independently like master theme only limited to master page component & mashup page utilized mashup theme only ) ?
Thanks in advance,
Shubham.
Hi @SP_9767292.
Per the case that was opened, your issue was resolved by upgrading to 9.0.7. If you agree that this was the solution, please mark this response as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
@SP_9767292 : I can see that this issue is being followed up on support case C15906999 where its mentioned this is a known issue. Please follow-up on that case itself for fix version.
Hi @SP_9767292.
Regards.
--Sharon
