How can we add keypress event in our textarea whenever a key is pressed in a textarea and a values is typed it should call a web service.
You may look into developing a custom java extension. Please see the documentation attached. Alternatively, you may reach out to your sales represenative to have you connected with the Global Services team - they could develop the solution for you (for a fee).
You need to create a custom widget which enables this feature. You can start from the default widget as a starting point or you can choose another one such as Google Widgets.
Varathan
