The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I use the collection widget and set it to :view=flow; FlowLayoutGravity = edge. Its internal elements are left aligned. Is there a way to make internal elements right aligned?
(ThingWorx 9.3.4-b1190 )
Thanks!
JiabaoXiao
Hi @JiabaoXiao,
If I'm understanding correctly in your query statement. Based on the Collection Widget Property - SectionInsetLeft / SectionInsetRight, statically you can adjust the cells from left to right and Vice-Versa.
Also 1 more option we can add 1 empty container to the left of collection widget placed container.
Thanks & Regards,
Arun C
Hi @JiabaoXiao,
Thanks & Regards,
Arun C
I get it. Thank you very much!
