How do I remove datashape field from below JSON output?
KN_9774047
"data": [
"usageId": "50030540014333322800000050",
"assetFound": true,
"compartments": {
"rows": [
"compartmentId": "50030540014333322800000052",
"observableProperties": {
"gatewayLocationDescription": "Ireland",
"temperature": 6,
"timestamp": 1612393200000
"compartmentUsage": {
"compartmentState": "Inuse",
"minTemperatureThreshold": 2.2
"compartmentId": "50030540014333322800000051",
"gatewayLocationDescription": "Belgium",
"temperature": 2,
"timestamp": 1612220400000
"compartmentState": "Idle"
"dataShape": {
"fieldDefinitions": {
"compartmentId": {
"name": "compartmentId",
"aspects": {
"isPrimaryKey": false
"description": "",
"baseType": "STRING",
"ordinal": 1
"name": "observableProperties",
"aspects": {
"description": "",
"baseType": "JSON",
"ordinal": 3
"name": "compartmentUsage",
"aspects": {
"description": "",
"baseType": "JSON",
"ordinal": 2
"message": "Information found",
"status": "Success"
6 REPLIES 6
suverma
(To:KN_9774047)
Hi @KN_9774047
You can refer to below link to get rid of datashape fields coming along in your JSON output:
Remove DataShapes from JSON Output
Do revert for more queries.
Sudeepta
KN_9774047
(To:suverma)
Tried that way in Thingworx 9.0.3 but not working out.
datShape field is still showing up in the output
suverma
(To:KN_9774047)
Hi @KN_9774047
I gave the code a try in 9.0.3 and able to get output without datashape. Sharing my script for reference:
Spoiler
var params = {
infoTableName: undefined /* STRING */,
dataShapeName: "DS" /* DATASHAPENAME */
// result: INFOTABLE
var result1= Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var newEntry = new Object();
newEntry.name = "test1"; // STRING - isPrimaryKey = true
newEntry.value = "test 1"; // STRING - isPrimaryKey = true
result1.AddRow(newEntry);
newEntry.name = "test2"; // STRING - isPrimaryKey = true
newEntry.value = "test 2"; // STRING - isPrimaryKey = true
newEntry.name = "test3"; // STRING - isPrimaryKey = true
newEntry.value = "test 3"; // STRING - isPrimaryKey = true
var param = {
table: result1 /* INFOTABLE */
var result = Resources["InfoTableFunctions"].ToJSON(param);
result.array = result.rows;
delete result.rows;
delete result.dataShape;
Spoiler
JSON Output:
"array": [
"name": "test1",
"value": "test 1"
"name": "test2",
"value": "test 2"
"name": "test3",
"value": "test 3"
Could you attach your service code here if still not getting output without DataShape.
KN_9774047
(To:suverma)
I am not allowed share the code.
But mine is a nested JSON.What you created is a straight forward one. It's not working with my output(nested)
slangley
23-Emerald II
(To:KN_9774047)
Hi @KN_9774047.
If you would like, we can open a case for further review of the problem.  I will be happy to open the case on your behalf.
--Sharon
Thank you. It's help me!
Fábio Valente - Developer and Solution Architect
