#1. Updating a remote bound property writes its property value to data tag of Kepware
#2. Updating the data tag writes value to the bound property
Will the #2 trigger #1 one more time ?
for exmaple : DataTagA get changed causing PropertyA get changed , and this changes on PropertyA send to kepare and change the DataTagA again, will it happen ?
Sean
Hello @seanccc ,
Could you pls clarify more about the use case?
Does your query implies if DataTagA changes in kepware and you change PropertyA on ThingWorx and than again vice versa?
Kindly elaborate in detail.
Regards
Bhawna
Hi Bhawna,
For the DataTagA and PropertyA , changes on either side will update the other side. Here is the case :
Time Action
t1 DataTagA changed
t2 PropertyA changed because DataTagA changed
t3 will DataTagA get changed again because PropertyA changed at t2 ?
Hi @seanccc.
Updates received into ThingWorx from Kepware should not trigger a looping effect.
Here's an article that provides details of the options for updating the property values, though it doesn't address your question specifically.
What version of ThingWorx are you running? Are you running into issues? Any errors in the logs?
Regards.
--Sharon
