I understood how to add editable grid but i dont know how it works when i view the mashup , as i cant edit it .please explain on how to access the grid when we are running the mashup.
You have to check the isEditable property of the grid, then go to Configure Grid Columns where you can check the Editable property in Cell Editing Options of particular column.
Hi ,
Thanks . But i already changed the settings in configure grid tab. but i dont see any change in the output of mashup .pls check the image attached, that is how my output is . i want to know how to add or delete columns in that .
Hi ,
I Have tried including the grid with editable options . But there is a tab called "validate expression" under the selection of edit column option . What expression should I provide under this ?
