How i can check if my thingworx is up and running?
YD_9850038
The use case is that i have machine that needs to call o make a call to the platform to check of it available before sending data. is there any embedded service that can do? any idea?
Yous
@YD_9850038
You can perform a simple REST call for a property or service to check the Thingworx status. If you get a 200 response that means your Thingworx is up an running. Alternate methods are documented in this article.
Sachin Sharma
@YD_9850038
Sachin Sharma
