How to Authenticate the API for Windchill Odata connector in Thingworx when using SSO Authentication
VV_14105315
Hi Folks,
I have a requirement to download the files of Windchill objects into Thingworx repository. I am getting the Link of files inside Thingworx using Odata Connectors. I am able to generate the file in Repository but when I try to open the file getting error "Failed to load PDF document."
Below is the code I am using :
// result: JSON
let inputJson = Things["ptc-windchill-integration-connector"].downloadAsZip({
respondWithZip: false /* BOOLEAN {"dataShape":""} */,
$expand: undefined /* STRING {"dataShape":""} */,
    objectId: <objectId>
// result: JSON
let csrf = Things["Thing.ODataConnector.ProdMgmt_TH"].GetCSRFToken({
$select: undefined /* STRING {"dataShape":""} */
    item = inputJson.items[0];
let params = {
url: <file_url> /* STRING */ ,
headers: {
"CSRF_NONCE": <Nonce token>,
                "Accept": "*/*",
                "X-Requested-With": "XMLHttpRequest"
// result: BLOB
let binaryContent = Resources["ContentLoaderFunctions"].LoadBinary(params);
    result = binaryContent;
    let fullPath = "/test4/" + item.name;
    Things["SupportRepository"].SaveBinary({
path: fullPath /* STRING */,
content: binaryContent /* BLOB */
What is wrong in my code to authenticate it while downloading it in Thingworx Repository.
Thanks in advance.
VV
Hello VV,
You should be getting the CSRF_NONCE token first and then pass it to subsequent calls - see example bellow:
let ParamA = {
    url: Windchill_URL + "/servlet/odata/v3/PTC/GetCSRFToken()",
const NONCE_VALUE = Resources["ContentLoaderFunctions"].GetJSON(ParamA);
let ParamB = {
    headers: {
        CSRF_NONCE: NONCE_VALUE
result = Resources["ContentLoaderFunctions"].PostJSON(ParamB);
 If you still get some error it would be helpful if you provide ThingWorx/WC log snippets.
