The error might be related to the SSL configuration or the port conflict, you can try to disable SSL in Tomcat's server.xml and see if it can be started.
To clone a system, you can refer to the the below steps:
1. On the source system, export all the entities and data
2. On the target system, install same version of Thingworx with the same version of JAVA/Tomcat/Database
3. Make sure the target system can be started successfully
4. Import the source entities and data in the target system.
For detailed steps, you can refer to Manual Migration of Thingworx to 9.x, although it is for Upgrade, but the idea is the same for the clone.
Hi @RP_9721615
It appears that there is a possible solution to your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
