Hello Everyone,
I have a ThingWorx instance hosted on an OCI (Oracle Cloud Infrastructure) server, and I would like to enable Single Sign-On (SSO) for the platform.
I am not sure about the correct steps or prerequisites for configuring SSO in this setup. Could you please guide me on the following:
What are the requirements for enabling SSO on a ThingWorx server hosted in OCI?
Which SSO protocols are supported (e.g., SAML, OAuth, OpenID Connect)?
Is there any documentation or step-by-step guide available for configuring SSO in this environment?
Do I need to make any additional configurations on the OCI side (networking, certificates, identity provider integration, etc.)?
Any best practices or common issues to be aware of.
Any help, references, or examples would be greatly appreciated.
Thank you!
I don't have experience with OCI, but will try to answer some of your questions nevertheless:
/ Constantine
Can't help on this specific situation, but the two main documents to read first are those:
https://support.ptc.com/help/identity_and_access_management/en/#page/iam/Welcome.html
/ Constantine
Hello @IS_11420788,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Hi @IS_11420788
Please let us know if either of the previous responses helped to answer your questions. If you're running into issues, providing the errors/logs would be helpful for troubleshooting.
--Sharon
