Is there any extension available for integrating the FIIX with ThingWorx?
There is a link in Vimeo: https://vimeo.com/683618643, in this video there is an extension present, is this available to download anywhere?
From watching the video it appears that the extensions are custom, developed by Rockwell Automation. FIIX is also a Rockwell product. PTC has no knowledge of FIIX or the extensions, so you will need to reach out to Rockwell.
Here's a link to the FIIX website: https://helpdesk.fiixsoftware.com/hc/en-us/articles/360018524352-Fiix-API-FAQ
Arshad
Looks like FIIX is cloud based and has an API so interaction should be possible through that.
I do not know if there is an extension.
Arshad
Hi @Arshad ,
When I Clicked on the Link, I got below:
- Thanks
