I want to reduce bar width in bar chart widget, i am currently using thingworx 9.1 version. I tried with all style properties but cant able to reduce bar width.
Please check attached images for reference
I believe you are using a bar chart from custom chart widget extension package, in that I believe there is no property to alter the bar width. If you can use ptcs-barchart(OOTB) bar chart in ThingWorx 9.x, there is a property called external padding which can be used to alter the bar width.
Thank you for reply@mnarang
i am using ptcschartbar in 9.1 version and i tried with external padding property but whole bar chart is decreasing, its not matching with my requirement
My requirement
Internal padding is increasing/decreasing the width of the bar, but the number of data points/bars remains the same on the chart. In your requirement number of data points/bars are also reduced.
Internal padding = 20
Internal Padding = 50
Internal Padding = 80
