How to add a baidu map widget or where to download the map extension?
YL_9503225
6-Contributor
Thingworx has the Google map widget, but i can't use it in my region. I want to use another Baidu or other map, but i don't know how to do. Who has good method? Thank you very much.
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:PaiChung)
Hi @YL_9503225.
If another community member is not able to offer a solution, you have the option of writing your own extension.  Here are some resources to help you get started.
Create An Extension
Create A Mashup Widget Extension
Packaging and Deploying Applications Built on the ThingWorx Platform
You may also want to post this as a request on the ThingWorx Ideas board.
--Sharon
6 REPLIES 6
PaiChung
22-Sapphire I
(To:YL_9503225)
We used to have a Baidu map widget on the marketplace but it looks like has been removed since.
You would need to create your own, you could take a look at the google map widget and redo it for Baidu.
YL_9503225
6-Contributor
(To:PaiChung)
Yes, I had searched in the PTC marketplace and didn't found the extension. It's a challenge to create a baidu map widget by myself. Do you know the reference about redo the google map?
PaiChung
22-Sapphire I
(To:YL_9503225)
Sorry I really don't have much more direction for you
slangley
23-Emerald II
(To:PaiChung)
Hi @YL_9503225.
Create An Extension
--Sharon
YL_9503225
6-Contributor
(To:slangley)
I'll try. Thank you very much.
YL_9503225
6-Contributor
(To:PaiChung)
Thanks all the same.
