Hello,everyone!
Why does it fail when I use the AddDataTableEntry service to add an image from a repository to a table?
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(test_grid_image)
let image_data = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
infoTableName: "InfoTable",
dataShapeName: "test_grid_image"
// result: INFOTABLE dataShape: "FileSystemFileWithLinks"
var fileList = Things["SystemRepository"].GetFileListingWithLinks({
path: undefined /* STRING */,
nameMask: undefined /* STRING */
var fileCount = fileList.length;
var f = 0;
for( ; f < fileCount; f++){
let newEntry = {
path: undefined, // STRING [Primary Key]
size: undefined, // NUMBER
downloadLink: undefined, // HYPERLINK
lastModifiedDate: undefined, // DATETIME
name: undefined, // STRING
img: Things["SystemRepository"].LoadImage({
path: "/image.png" /* Replace with youe actual image paths*/
}) // IMAGE
image_data.AddRow(newEntry);
result = image_data;
It worked for me.
Hard to tell with the information given. Check the logs. Maybe the user lacks access/service execute privileges to access the file.
Maybe it does not get added to the DataTable. Maybe it's not queried correctly. Maybe the type is wrong.
Check if the link is contained in the datatable. Check the link is contained in the infotable you use as data source in the grid.
Ok thanks, I'll check the logs afterward!
hi @Snoopy_hu ,
In Column format of the colum "cImageLink" what did you give it?, it should ImageLink type
Yes, I chose the imagelink type.
var f = 0;
let newEntry = {
}) // IMAGE
It worked for me.
Ok thanks, I'll give it a try as soon as possible
