How to adjust the margin in a Tabs widget?
SOLVED
Highlighted
Garnet
In Thingworx8.5, a style with attribute part='pages' is attached to Tabs' content. The margin value set in the style is too large. How can I change the margin value?
1 ACCEPTED SOLUTION
Highlighted
Re: How to adjust the margin in a Tabs widget?
Try with custom CSS, like below:
ptcs-page-select::part(pages)
margin: 10px !important;
Hope it helps,
Raluca Edu
2 REPLIES 2
Highlighted
Hope it helps,
Raluca Edu
Hi @zhuwenxi.
If the response provided by @raluca_edu answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
