How to all names of properties of thing template?
nbhagtani
How i can get list of all properties defined in thing template?
GetNamedProperties -> service takes json but i don't have any parameter just need all properties list.
7 REPLIES 7
AnnaAn
(To:nbhagtani)
Dear Nisha,
You could author it like this:
Attached code here:
var params = {
category: undefined /* STRING */,
type: undefined /* BASETYPENAME */,
dataShape: undefined /* DATASHAPENAME */
// result: INFOTABLE dataShape: "PropertyDefinition"
var propertys = me.GetPropertyDefinitions(params);
var propertyList = new Array();
var tableLength = propertys.rows.length;
for (var x = 0; x < tableLength; x++) {
var row = propertys.rows;
//Your code here
    logger.error(row.name);
    propertyList.push(row.name);
Br,
Anna
nbhagtani
(To:AnnaAn)
Hi Anna,
I need output of this service. What base type to give to "propertyList"? If base type is infotable then i need to create data shape as well
Yes Nisha if you want multiple records you should have infotable and to see that on mashup you will need datashape
I don't want to use it on mashup. My other service just needs properties list of template.
so is it possible to have infotable only having properties list?
I have a solution that might not look good but i think will do the work. just get result as a string with appended property list  separated with comma and in next service take it as a input parameter and using function get the separate property string using comma as string separator.
AnnaAn
(To:nbhagtani)
Hi Nisha,
If you want to return an InfoTable, a more straightforward way would be like this:
Attached the code here:
var params = {
var properties = me.GetPropertyDefinitions(params);
var result = properties;
The PropertyDefinition is a build-in DataShape, so you do not need create again.
Br,
Anna
vr-6
(To:nbhagtani)
var params = {
// result: INFOTABLE dataShape: PropertyDefinition
var info1 = Things["YOURTHING"].GetPropertyDefinitions(params);
var params = {
infoTableName: undefined /* STRING */
var infotable = Resources["InfoTableFunctions"].CreateInfoTable(params);
//Add a new field to the InfoTable:
infotable.AddField({name: "PropertyName", baseType: "STRING"});
infotable.AddField({name: "BaseType", baseType: "STRING"});
var newEntry = new Object();
    for (var  i =0; i<info1.getRowCount(); i++)
  newEntry.PropertyName = info1.rows.name;
  newEntry.BaseType = info1.rows.baseType;
  infotable.AddRow(newEntry);
var result = infotable
Hope this will work.
Create Thing for your ThingTemplate and Replace "YOURTHING" with ThingName
Set your service output as infotable.
