Hello ,
I have a regular grid widget, how to allow the user to select the text from the cell for copying., It is a read only grid.
Is there a setting for the same..?
Sunay
Just for selection I believe most browsers allow just double clicking or drag highlight.
What are they supposed to do with the information that they select?
Chung,
When you double click it ll select the entire row, and also drag highlight is not possible.
The intention behind is, user wants to copy the formula displayed on the grid.
Sunay
Although not the greatest way, you could set that Field to be an editable field, that should allow selection.
