How to call services of one thingworx in other thingworx?
ranjank
Hi Team,
Suppose I want to call one common service of 5 ThingWorx Environments in one service of master ThingWorx environment (can say 6th environment) to see the result on any mashup in 6th environment.
Result on mashup in 6th enironment will be like :-
Env1---> ResultOfEnv1
Env2---> ResultOfEnv2
Env3---> ResultOfEnv3
Env4---> ResultOfEnv4
Env5---> ResultOfEnv5
What would be the solution?
Thanks in advance.
ranjank
(To:zyuan1)
Hi @zyuan1 ,
Below solution has worked for me:-
PostJSON() is used for executing services and GetJSON() is used for getting property values of any other ThingWorx environment.
Atlast I have shown the result in of a responsive Grid on mashup
2 ways.
1. Use REST API call to retrieve information
2. Federation settings, it can share Stream, Datatable information
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx%2FHelp%2FComposer%2FFederation%2FFederation.html
ranjank
(To:zyuan1)
Hi @zyuan1 ,
Can you pls share the snippet of using REST API for accessing Things and Services of other environment ThingWorx so that I can have a try.
I'm thinking about using Link widget in the mashup with a popup window, and the Link will navigate to the mashup from another TWX server.
While talking about requesting through services, I'm thinking about whether GetJson, LoadXML services could work, and put REST request in their content, and pharse the result back to infotables and strings.
ranjank
(To:zyuan1)
Hi @zyuan1 ,
