How to center align Grid header and value using Style Theme
Velkumar
Hello all,
How to center align Grid Header and Value using style theme
/VR
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:Velkumar)
Hi @Velkumar.
Several changes were made affecting widgets in ThingWorx 8.5.1.  It is recommended that you upgrade (the latest release is now 8.5.4).
If you still have issues after upgrading, you may need to look at using CSS to address your issue.
Regards.
--Sharon
8 REPLIES 8
Hi @einsfeldleo ,
Thanks for your response.
I tried it gridadvanced widget, it doesn't work.
/VR
slangley
23-Emerald II
(To:Velkumar)
Hi @Velkumar.
From our testing, we're not seeing an issue.  If you select the grid, in the upper-left corner is a drop-down.  From there you should select Configure Grid Columns.  You then have the ability to align the header or the data.
Please let us know if you're still having issues.
Regards.
--Sharon
Velkumar
(To:slangley)
Hi @slangley
Thanks for your response. I have mapped configuration dynamically, so I'm not able to find 'ConfigureGridColumns ' in widget.
In configuration, I have mentioned 'textAlignment' as center
Still header and text are not aligned
/VR
slangley
23-Emerald II
(To:Velkumar)
Hi @Velkumar.
Which version of ThingWorx are you running?
Regards.
--Sharon
Velkumar
(To:slangley)
Thingworx 8.5.0
slangley
23-Emerald II
(To:Velkumar)
Hi @Velkumar.
Regards.
--Sharon
slangley
23-Emerald II
(To:Velkumar)
Hi @Velkumar.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
