i hope to change the fonts size of display content in the Property Display Widget.
I had change the "Style", but it fonts size does not change at all.
Can anyone guide me how to change the fonts size in Property Display Widget?
any tutorial or document that i can read up.
Thank you
Newie Kek
Have you considered looking into custom css? http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FMashup_Builder%2FMashups%2FCustomCSSTutorial.html
I changed the ValueFormat of Valuedisplay widget, and the font size changes.
The screenshot come from same mashup, with 18px and 11px Text Size in Style Definition in ValueFormat.
Background color is from Style Theme definition, not related to the problem
The tutorial working but.....I tried and struggled on the Property Display...
I hope to know how do i class the "Property Display" Text?? or Value Display.
I use Ctrl-->Space but do not know which element is should use.
Is there any references i can read up. Hope you can direct me there!
Thanks!!
Best regards
Newie Kek
