You can find using following steps,
1. Get parent of current node
2. Get Child list of parent node
By comparing child count you can find.
Hi ranjank,
I have created a query to get relation between a parent node and it's child. Every child within a parent can be grouped as siblings.
Please use the entities I have attached for the service I have created for above mentioned scenario. This can also be modified to get the count of sibling.
Do revert for any further queries.
Sudeepta Verma
