How to convert Infotable into JSON in Java Extension
SathishkumarC
6-Contributor
How i can convert Infotable into JSON
Since toJSON() function Deprecated. no replacement
@Deprecated
 @ThingworxExtensionApiMethod(since={6,6},
                             deprecatedSince={8,4})
public org.json.JSONObject toJSON()   throws java.lang.Exception
Any other methods available?
Sathishkumar C.
4 REPLIES 4
Hi @SathishkumarC.
This article may provide some guidance even though it relates to a service.
--Sharon
Thank you for reply.
I know this with Thingworx. But the same thing I am trying to use in Java extension it was telling "Deprecated". If I am continue to using the same method will I face any issue in future?
slangley
23-Emerald II
(To:slangley)
Hi @SathishkumarC.
In some future release, deprecated extensions will be removed, but we do not have specifics on when that will occur.  That information will be detailed in the release notes for the relevant release to allow for modifications prior to upgrading.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @SathishkumarC.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
